Old 08-04-2009, 02:00 PM   #8 (permalink)
wagonman76
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Originally Posted by JacobAziza View Post
What might be slightly more challenging is finding a normally closed relay.
A typical automotive 30A relay (at least all the ones I have used) can be used normally open or normally closed. There are 5 pins. 2 for the coil. 1 for the common terminal. 1 for normally open to the common terminal. 1 for normally closed to the common terminal.
I would just tap into the a headlight wire and use it to power the relay coil. Run your DRLs through the relay, normally closed, so when the headlights are on, it will break the circuit to the DRLs. I've never used a diode but it certainly couldn't hurt.
Winter daily driver, parked most days right now
Summer daily driver
