A turbocharger allows you to downsize your engine while retaining the power of a larger engine. This also allows increased engine loads while cruising which is the main benefit of the smaller engine.
In your case, you already have a fair size engine for the size of your car. The turbo is just a power adder to an adequate engine. I'd do as you have been and just keep rpms low and stay out of the boost.
