1) Yes. CRX's are more fun to drive.
2) CRX's are non-OBD, unless you update the car. Getting an HF doesn't give you an update option without losing the HF engine, so the only real choice is to go to a D15Z1 engine and full ECU swap.
3) No, except maybe the Si models, which would be able to be retrofitted to your HF
4)HF doesn't, Si's do. Some DX's I think. If you don't want it, the Civic and Civic DX racks will fit easily, they only take an hour to change.
5)Not even close, but the B6 is the 8-valve EGR'd version of the D-series engine, which will get you ~50 MPG w/o trying, if you keep it running correctly.
6)Depends on what parts, but not particularly. Some people want to charge a mint for them, though.
7)No, Hondas are actually very reliable. I hardly ever had to replace too many parts, excepting maintenance items, like ball joints and tie rods.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
