Originally Posted by RandomFact314
So can anyone with a crx or that used to have one tell me if having the rear windshield wiper is worth it? Does it help a lot during rain, we seem to get it a lot down here sometimes...
I've had 2 CRX's with rear wipers, 1 without, and Cara has one, but it doesn't work.
I don't use the inside mirror enough to care about the rear window, but on one of the CRX's, when I bought it, the wiper worked. I didn't use it for so long that moisture built up in the motor and froze it. As long as you clean your car once in awhile, you shouldn't have a problem, and airflow is attached there, so if you wax the glass, the water will sheet off fairly well.
