It depends on how you setup the
scangauge. You can program the
scangauge to calculate fuel cut off on coasting. Or you can program scangauge to assume you idle on coasting in gear. How do you know what your fuel injector actually do so you can program your scangauge? Does anyone know a place to look this up or a way of determining. I'll do some searching to see if I find any answers.
