Re: the centre light. You could just apply some heat gun to the kamm back and bend that part of it down. It would leave the rest of the kammback to do it's job while you had visible brake lights.
You also mentioned the similarity to a nuns cornet. Might i suggest the name "Nunnback" for your creation? It's up to you, but it cracked me up on the way to work! I definitely got about 30km out of it!
In any case it seems you got some decent improvement in drag reduction as per your last post. Kudos to you!!! I bought ecomodding material about two months ago and still have to do something with it!!!
ollie
