Old 08-07-2009, 08:02 PM   #1 (permalink)
Hermie
Stickers - '91 Tempo GL
Send a message via AIM to Hermie Send a message via MSN to Hermie Send a message via Yahoo to Hermie
Newbie Ford Tempo owner
Hello! I found this site looking for information on vortex generators, and seeing that there's tons of other discussions for aero mods, I thought I'd drop in.
I'm actually more interested in eliminating aerodynamic lift than anything, and if I can decrease drag at the same time, all the better.
My car is a 1991 Ford Tempo GL, and I've already done a couple of aero mods.
The first thing I did was install hood vents to reduce front-end lift and promote increased engine cooling.
Second, I pulled that flap under the radiator forward to act like a scoop, so that if either air is pushed up by it, or air pushes down on it, downforce will be created. ^^
Third, I installed some tire spats in front of the rear tires, using my front license plate holder for material. Turns out they're the full width of the tread!
I'm considering vortex generators, since the rear window angle on a '91 Tempo is about 35 degrees, give or take, but I first want to find out if I'll be increasing lift by using them. If that's the case, I'll pair them with a decklid spoiler to counter that lift.
I'll probably be posting around...
