There's not much to worry about as far as stability and staying on the road, but structural integrity and safety come into play when you start removing too much stuff from the car. But if you're only removing or replacing the 'visual' things, then there's not much to worry about.
When you start drilling holes in the frame of the car trying to save weight, then you might need to worry.
