Old 08-08-2009, 10:12 AM   #10 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Originally Posted by MadisonMPG View Post
It seems that no matter what I post you contradict me, because of this I am no longer going to read anything you type.
Fair enough. When you make a blanket statement, you should prepare to be contradicted by anyone. I'm just not so shy about it as others are.
If it eases your mind, there were probably other problems with the clutch assembly as well, but the release bearing did, in fact, explode, causing damage to other components. The car had the OEM clutch with 180,000 miles on it, but that's beside the original point.
