...a simple vacuum switch "Tee'ed" into the intake manifold should work, with the switch set to OPEN when the vacuum drops below a preset value (about 10-14 inches Hg), and being wired into the hot line to the A/C compressor clutch.
...thus, when the manifold vacuum is HIGH (idle, light cruise, etc.) the switch is CLOSED and the A/C compressor clutch will operate as normal. But, when the manifold vacuum is LOW (accelerating or heavy load (hills), etc.) the switch will OPEN and the A/C compressor clutch will be disabled (only the compressor is disabled, all other fans/etc. continue working as before).
...might want to look into also installing an suitably size RC-snubber circuit across the vacuum switch contacts, as the inductive "kick" from the A/C compressor can/will eventually "eat" the vacuum switch contacts.
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SIDI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
