Old 08-10-2009, 12:51 AM   #16 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
Originally Posted by nubbzcummins View Post
Even tho there are air bubbles in the tank/fuel they will be consistent as long as you fill up at the same rate with the pump every time..........which I do.
Not true. When you fill it to the brim the air bubbles that gurgle out of the tank are what determine the final rate at which fuel flows into the tank. There is no way to get the gurgling to be consistent.
Even if find a way to to fill it the same each time you would still have too much variance in the road travel draw any valid conclusions with just one tankfull.
