Thread: Solar Roof
Old 08-10-2009, 02:11 PM   #24 (permalink)
gascort
gascort's Avatar
Gascort - '93 Escort Wagon
90 day: 43.01 mpg (US)
There is; the dump controller can put extra charge into anything; a plain old resistive block heater would work as a dump load, even if it's set up for 120V.
Will it warm up the motor? Not even close to significantly, but every bit helps I guess.
I'm going to try to dump the extra juice in the summer to the car's fan; it will be interesting to see if it can start the fan without a capacitor and some extra circuitry.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
