Old 08-10-2009, 05:55 PM   #2 (permalink)
Matt Herring
Matt Herring's Avatar
Bone's 2010 Prius - '010 Prius Black
90 day: 56.78 mpg (US)
Depends what type of tire you deleted and what type of tire you added. If you removed LRR tires and added a HRR tire you will lower mpg. If it's the same tire you will have a breaking in period for the new tires that will lower mpg. Are all the tires the same size (just asking as they could throw off the odometer as well...hoping they are all the same size).
Also, any added weight in the car will lower FE. Your seats could be an extra 50, 75, 100+ lbs. that you are dragging around in the car now.
Both of these events (plus any bad for FE weather) can all have negative effects on your FE.
The Following User Says Thank You to Matt Herring For This Useful Post:
Eddles (09-06-2009)
