Old 08-13-2009, 06:47 AM   #6 (permalink)
silicon_toad2000
toad - '84 Landcruiser FJ60 G
90 day: 9.84 mpg (US)
I'd say the OEM's would have already tried that.
You won't know until you do some partial throttle dyno runs.
Supposedly the magic number is that the mixture should reach full combustion/maximum pressure at 14 degrees after TDC. So you need to ignite the mixture at a point early enough that the mixture is all combusting at that point.
