Originally Posted by watt-a-mezz
I am glad to know I didn't mess the cables up. What you describe is very close to what I made to fit on 2/0 welding cable for my battery pack. I may try washers to insulate and keep them tight on the wing nut posts. Thanks again for the help. Watt
It's probably a good idea to tin them with solder once you've made the size of lug that you want, though. Lead and tin don't oxidize like copper does. Prefer you to use tin solder, not lead, but if that's what you got, I guess it's as good as any.
You could also do an alum dip, if you're OK with chemistry.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
