Old 08-13-2009, 08:18 PM   #3 (permalink)
some_other_dave
jedi, short of having two meters to use at the same time, you would need to re-set the meter (including moving the red lead from the one socket to the other, and setting the function of the meter to reading volts in the roughly 0-20V range) in order to check the voltage.
So yes--you're right.
-soD
The Following User Says Thank You to some_other_dave For This Useful Post:
jedi_sol (08-13-2009)
