Thread: Success, kinda!
Old 08-14-2009, 02:06 PM   #15 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Another relatively low cost option for your cable ends (depending on strand size) is to tin them directly.
The majority of the 2/0 connections on the ForkenSwift were hammered relatively flat, then I wicked solder into them, making them solid. They were then ground flat & drilled for the battery post bolt.
DIY end top, OEM bottom:
I also tried the copper tube sheath approach, but it didn't work as easily:
For more info/details on how these were made, see starting around post # 406 in the ForkenSwift build thread, roughly here: http://ecomodder.com/forum/hreshowth...3-post763.html
Several years later, they're still working fine (not getting hot or flattening out/creeping).
watt-a-mezz (08-17-2009)
