Found injectors that might work for the 1.3L swap: 2003 HONDA CIVIC HYBRID 1.3L 1339cc L4 ELECTRIC/GAS FI [LDA1] : Fuel/Air : Fuel Injector. If you go to RockAuto.com you can see a pic. You might have to get a wire harness from a wrecking yard so that you can clip the plug-ins off to solder them to your existing wire harness. Remanufactured injectors are $36.89 on the web site.
