Help Me Name This Product (commercially produced Prius grill block)
I have a name in mind but do not want to influence any ones judgment.
If I pick your product name you will receive the product free.
Keep in mind this first product is for the prius BUT it will need a name THAT WILL WORK WITH ALL CARS that the product will eventually fit. I am sure other car owners will ask if I can make one for there car,truck or Suv.
I will get a picture soon.
The part covers the lower bumper intake and it is flush (follows the bumpers factory shape) with the bumper.
It also has a small concave ridge that follows the original hole opening. Which should assist alignment of the product during installation.
The product will also extend 3/4" past the original hole size around the perimeter.
As far as attachment you could use double side stick tape,silicon on the flange or epoxy mounting tabs on the inside to accommodate some type of zip tie or strap to hold it in place.
I am in the process now of tuning the mold and will have some parts out very soon.
To speed up the time to get the product on the market I am thinking of releasing the product with no holes or vents.
I still not have not found a supplier of rubber or plastic caps to fill holes.
(1)Maybe someone here can help me name the product.
(2)Maybe someone knows a manufacturer of rubber or plastic plugs for around
1 1/2" to 2" holes and will be flush with the part surface.
Thanks Franklin
