Old 03-01-2008, 11:15 AM   #4 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Note that the water apparatus was used for visualization purposes only, not measurement -
The water tunnel allows for visualization of the flow as it reaches and flows over the pickup truck. Points of separation and turbulence were to be recognized.
The wind tunnel was used to gather data: (p.7)
The wind tunnel consists of a nozzle inlet, a constant area test section (plexiglass), and a diffuser exit. At the exit is located a high-powered DC motor (one speed) and a fan to draw the air through the test section. A model is secured in the test section to a scale balance located below which reads draf force (lbs-f) and lift force (lb-f)
The Scale Balance was calibrated prior to testing, to "allow measurement from the wind tunnel to be converted to an actual drag force value."
Wind tunnel balance scale calibration curve.
