Old 08-17-2009, 12:17 PM   #1 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
AutoSpeed: "FuelSmart" device: sort of a live BSFC indicator
Julian Edgar has posted the first of a two part series about an electronic project device called "FuelSmart" that he's impressed with:
If you have a manual transmission car and the engine uses a MAP sensor, this device can improve your fuel economy by up to 15 per cent.
To be clear, it's not a vehicle mod, but instrumentation using vehicle sensors to help the driver use the go pedal smarter to save fuel.
See: FuelSmart - Part 1
Essentially it monitors throttle position (via the TPS), and engine load, via manifold absolute pressure (MAP) sensor. If the unit detects inefficient engine operation, it lights up a red LED. EG, under low load and a mostly closed throttle. The LED is the driver's reminder that s/he can get better economy either by giving it more gas, or increasing load (upshifting) if you're trying to accelerate or climb.
Or if you're approaching a stop, it's a reminder to fully release the throttle and go into DFCO mode (Deceleration Fuel Cut Off), rather than very lightly motoring along in a very inefficient engine operating range.
The article also explains the pros/cons between this device and a simple vacuum gauge.
My main criticism with the piece is it muddies the waters about what "pulse and glide" is (discussion of BSFC often includes a P&G description, as this one does). It essentially describes "Pulse and DFCO", not Pulse and Glide. DFCO necessarily occurs in gear, with engine braking slowing the vehicle as a result. DFCO is not a true glide. A true glide occurs in neutral and will out-distance DFCO. Engine-off gliding will beat DFCO every time in terms of better fuel economy.
Full details: FuelSmart - Part 1
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
al_capwn (03-21-2010), dremd (08-17-2009)
