Thread: Tire choices
Old 08-18-2009, 06:53 PM   #14 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Originally Posted by Huntr View Post
According to Carlisle Tire (and every tire website I found today looking for 4.80x12 tires), a 4.80x12LRC tire has a capacity of 990 @ 90 PSI. It's the 4.80x12LRB that has the 785 @ 60 PSI. 990 to 1036 is not much of a difference.
You are correct, but the original post was about 4.80-12 Load Range C's at 60 psi - and in that case the load carrying capacity at 60 psi is indeed the same as the Load Range B - 785#.
There is either have a large difference in load carrying capacity or a large difference in inflation pressure needed for the load.
