Old 08-20-2009, 03:14 AM   #6 (permalink)
nickdigger
Originally Posted by gtkid2002 View Post
I drive an '89 Prelude Si. It uses a mechanical speedometer. The 90/91 Preludes do not. Now, the problem with the 88/89's is a gear on the inside of the speedometer wears out. Then your speedo no longer works when YOU want it to, but at it's own discretion. So I almost need the mpguino to double as a speedometer, with the function of the mpg gauge secondary.
Hope i'm not missing something here, but if your speedo is mechanical, do you even have a VSS?? And without a VSS, isn't the mpguino basically a paperweight?
