Thread: Tire choices
Old 08-20-2009, 08:55 AM   #17 (permalink)
MechEngVT
Mechanical Engineer
The Truck - '02 Ram 1500 SLT Sport
90 day: 17.8 mpg (US)
The Van 2 - '06 Odyssey EX
90 day: 18.48 mpg (US)
Golf carts are almost universally 4x4" bolt pattern. I think the Austin Mini used that pattern and essentially the same size wheel/tire as golf carts, only a bit narrower.
You can get ultra-lightweight single-pieced forged alloy wheels for racing minis (wheel is IIRC 12" and like <8 lbs) and DOT winter tires from Yokohama and the mounted/balanced wheel and tire are <17 lbs. I know someone who tried this on a golf cart to improve ride on pavement-only operation, and I want to say it was right at $100 per corner for this.
The winter tires were used because they were the only thing (or the only light thing) available in the OD required for a golf cart. Stepping up the OD slightly would probably open a few options, reduce rolling resistance, but slightly increase weight and inertia.
