decent thoughts. As I believe the auto industry is backwards attacking the engine with hot air is thier win. the engine is not gonna last. The company that made it won..as long as somebody got something they wanted out of the temporary dud called fuel injection.
If for example we take a pretty common direct stratified inject petrol engine that doesn’t require the fuel mix to vaporise in between an old school carb and piston would have though the best thing is to have cold dense air to create the most complete bang from a tiny amount of a hi octane fuel?
all fuel has to vaporize. injected or not. the carbs go all the way to helium lightweights and needs more discipline in more than one category of fuel delivery..except for energy used to make it work. A bad day is known with a carb engine..the fuel injected on a bad day is a fire engulfing the car. (bad day is gassy polluted air).
the big bang theory is a good one. the most power for the least consumption, its called efficient. If one cannot control thier own system, it needs tricks, and they will be backwards attack and associated with a nation of origin..don't even get me started.
