Old 08-21-2009, 12:11 PM   #20 (permalink)
tasdrouille
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Originally Posted by JacobAziza View Post
(I'm assuming that is a diesel specific BSFC map?)
It is for the TDI engine found in my car.
Why idle? EOC requires 0hp
Good question. My turbo is oil cooled. I'm not sure repeatedly boosting at the maximum output and then cutting the oil supply would be a very good idea in the long run.
What did you base the numbers 15hp for steady state and 45hp for accelerating from 45mph to 67mph on?
The 15 hp is an approximation it takes my car to keep going down the highway at roughly 55 mph.
The 45 hp is the average available power I pulse at. You can see the hp lines on the bsfc map. Close to the maximum power output available in this rpm range.
Honestly the biggest guess here is not the power requirements, but whether the 1/3 pulse 2/3 glide ratio is right. This is what have the biggest impact on the outcome.
www.HyperKilometreur.com - Quand chaque goutte compte...
The Following User Says Thank You to tasdrouille For This Useful Post:
JacobAziza (08-21-2009)
