You can use this nifty calculator Darin put together to calculate your HP requirement at speed. You can access it from clicking "tools" at the top of the page.
Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com
Horsepower requirements for cruising are pretty small.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - Efficient living and green home improvement
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
