Old 08-22-2009, 04:25 PM   #4 (permalink)
greasemonkee
For what it's worth,
The Innovate units, more expensive versions, have programmable analog outputs for the O2 signal, not sure if you can modify a narrowband voltage scale with it though if that's what you're after. I see they have out more affordable controller and gauge kits now also (low 200's) if you just want to monitor.
PLX controllers have been around a while, tried and true for low-mid $200's
NGK units seem sturdy from what I've heard.Techedge pieces are decent as well, an australian company with various models (with the option for an NTK sensor).
Some widebands are notorious, and seemingly destined, for failure so research good before you buy.
Most widebands have a narrowband output along with the wideband output, it really depends what you want to do with it. Some prefer linear output voltage scale controllers as they are easier to set up in tuning software.
I still use a trusty old school plx m300 that has been reliable for 5 years now.
