Old 08-22-2009, 09:04 PM   #3 (permalink)
Intrigued
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Intrigue GX
Last 3: 25.94 mpg (US)
LOL! I have one of those, except it's yellow instead of blue!
The book on the thing says it will go 20 miles on a charge, but I can guarantee you that they really meant 20 BLOCKS!!!
Anyway... I took the body off of mine a while back, to see how everything worked, and promptly added two batteries to the two already there, for more range.
I tried to wire it up with 48 volts instead of 24 (MORE POWER!!!) but the controller cut power to the motor instead. I added a 6-volt battery to make 30 volts for a while, and it had more power, but things started smelling funny, so I just did the two strings of batteries for the 24 volts with more range, and the voltage doesn't drop so bad when you gun it!
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
