Old 08-23-2009, 01:07 PM   #1 (permalink)
Ptero
Ptero's Avatar
Smart Car ForTwo Pure - '08 Fortwo Pure stripped
90 day: 51.35 mpg (US)
BMW 750iL V12 - '90 V12
Wildfire 250C - '08 250C
Areas To Avoid In Cross Country Mpg Trips
AREAS TO AVOID IN CROSS COUNTRY MPG TRIPS
courtesy of ExxonMobil
ETHANOL IS FORCED ON CONSUMERS OF SEVERAL STATES AND METRO AREAS, REDUCING MPG BY ABOUT 30%. ALL OXYGENATED GASOLINE CONTAINS ETHANOL. FUEL UP OUTSIDE THESE AREAS FOR DRAMATIC MPG GAINS! I DO - AND I GUARANTEE THAT IT WILL MAKE A HUGE DIFFERENCE.
http://www.api.org/aboutoilgas/other...ements_Map.pdf
http://www.exxon.com/USA-English/Fil...p%20100102.pdf
IF YOU REALLY LOVE ETHANOL, YOU CAN MODIFY YOUR ENGINE WITH HIGHER COMPRESSION AND DIFFERENT TIMING TO RUN ON ETHANOL-RICH GASOLINE OR PURE ETHANOL FOR AROUND $2000 TO $5000. BUT IN CONVENTIONAL GASOLINE ENGINES, INCLUDING "FLEX FUEL" TYPES, ETHANOL SERVES A PRIMARY PURPOSE AS AN OXYGENATOR AND A SECONDARY PURPOSE AS A LOWER QUALITY FUEL. THIS ROBS MILEAGE AND THROWS AWAY ANY SO-CALLED "GAINS" FROM AGRICULTURAL FUELS. IF YOU HAVE ANY DOUBTS ABOUT THIS, SIMPLY MAINTAIN A MILEAGE LOG ON YOUR NEXT CROSS COUNTRY TRIP - USING THE ABOVE MAPS. THE DIFFERENCE IN MPG WILL BE LIKE A SLAP IN THE FACE.
THE ETHANOL MANDATE IS A PAYOFF TO THE FARM STATES BY POLITICIANS. AND NOTE THAT MOST OF THE FARM STATE AREAS DO NOT HAVE ETHANOL MANDATES.
I ASKED A FARMER WHY THEY DON'T RUN THE ETHANOL THEY MAKE IN THEIR OWN FARM EQUIPMENT. "WE'RE NOT STUPID," HE TOLD ME. "WE CAN'T GET ANY POWER OUT OF IT!"
