Originally Posted by cfg83
Christ -
I did this last week on a steep downhill on the freeway (405 North on the way to the 101 East). I had to put it in 4th gear. I felt like a "sinner" because I was over 3100 RPM, but lo and behold the AFR gauge went lean so the fuel savings is there to be had.
CarloSW2
Carlos -
Next time, wait till the indicator goes lean, then quickly shift into a higher gear without letting the engine idle at all. You might stay in DFCO at a lower RPM that way. Worth a shot, I'd think?
