Set screws AWESOME!!! You should only need one, make sure the slop is all on one side.
Also, do the final line up and adjusting assembly of your adapter while texting, or in the shower, or while texting in the shower.
Also, DO NOT WELD IT TOGETHER, if some of the scale from the weld comes off while running it could cosmetically damage something.
