I have two trailers, a 4x7 one with 1' sides and a boat trailer with a 4x8 sheet of plywood on it, the boat trailer has a rack on it so I can carry two small snowmobiles on it. I've had both trailers up to 1500lbs hauling hay or firewood and the tracker hauls that around fine. I read that in europe and australia the same vehicle could tow 3300lbs with trailer brakes. That would make the engine work on the uphills for sure but with a manual trans it should be no big deal.
