well a little update.
I will not be using the V6 , not that there is anything wrong with it but I want and need to be different
and I will be using a 1988 Escort GT 1.9L HO but insted of MPFI I will be running a 2 barrel carb from a 1982 ford escort.
I will be using the same tranny I was going to use with the V6 wel lthe same diff since they are the same. I will insta lthe tallest
gears and ratio I can and make it light and cut the air like a bullet . the 1.9L 4 cylinder is almost a drop in for this car not much modding to do.
and 60mpg is posible if i set it up has a lean burn and that is ezzy to do with a carburator. I have done 2 cars before for MPG challenge but back then
its because i was poor and needed to save some cash and I sure do love to drive. but this time its for less polution and pure fun and because I can.
FRANK
