Old 08-25-2009, 08:58 PM   #19 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Originally Posted by cfg83 View Post
Yes, bump starts are for MT only.
With many ATs, you can leave the vehicle in "D", make sure it's in TC lockup and turn the key off to cut fuel delivery and engine brake. Then, you can turn the key back to the On position without using the starter.
Modern engine will cut fuel on decel anyway (DFCO), but if you need that in-between of compression braking without downshifting into a more aggressive gear, it's something to consider.
Since you lose ABS, Airbags, and most importantly, the Radio, a fuel-injector cut switch might be the best option for this.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
