Nice work.
A quick word for the less experienced though, when you use roloc discs on an aluminum head or block you must be extremely careful not to over do it or you will end up cutting into the soft aluminum. This will result in a poor headgasket seal and you may end up needing to get the head or block refaced.
Ive seen this done in my shop a time or two and its not pretty.
Done right however the rolocs are amazing for gasket removal and sealing surface prep.!!
