Changing 4 port blow off valve
I am looking to upgrade the piping preturbo on my Move. Plan is to install water injection before the turbo to help keep the pipes and air cooler. The system is speed density, so unmetered air is not a problem. The problem is the hoses. There is one hose from the valve cover to the BOV, one hose from post turbo to the BOV, one hose from preturbo to the BOV, and one hose for vacuum/boost signal. I am a little confused as to what hoses I can or can't keep. I want to delete the pre-turbo connection just to make the preturbo pipe easier to make, but don't know if the valve cover hose is needed or not. Any comments? This is a JDM only car, so the name won't really help. I can take pics if they are wanted or needed.
