Old 08-30-2009, 02:56 PM   #24 (permalink)
JasonG
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
Most test shops partially block the tail pipe. Any whistling means there is a leak that must be fixed for safety reasons.
I assume you have a sedan. The DOT law states that all exhaust must exit behind or above the passenger compartment.
Even if you dont feel the leak is entering the passenger compartment because your windows/floor/etc is sealed, it is still a hazard.
Bottom line, you had a dangerous exhaust leak and fixed it. You are safer now. The actual gas emissions are really irrelevant.
