Old 08-30-2009, 03:35 PM   #6 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
I'm not sure of the ingredients in the Dipetaine mix. Other forum members prefer "AutoRX" if it's available there (and if it's OK for Diesels). I just have used Seafoam with good results (and it's at the local parts store), and especially through the brake booster line. At another forum, I found a quote with the ingredients:
50% light hydrocarbon oil (pale oil), 30% petroleum naphtha, (charcoal starter fluid/mineral spirits), 10% isopropyl alcohol, and 10% water.
I suppose one could make their own with similar ingredients -- some agree with using just water through the booster -- Police, taxi, and other fleet mechanics use water, but I worry about getting the right amount).
To really clean out the deposits and carbon, find a product to add to the brake booster line when the engine is running. SF makes a LOT of white smoke, especially in vehicles with significant buildup. So far, I've used it in:
-1993 Chevy Pickup, 5.7L (engine would not crank due to severe overheating, dumped SF into the spark plug holes, let soak, and it started and ran 500 more miles and still today as a farm vehicle).
-1995 Mercury Mystique (Mondeo) 2.0L Zetec
-1998 Integra 1.8L (multiple treatments in brake booster, fuel tank (injectors), and in the crankcase to break up sludge before an oil change)
-2005 Honda Civic 1.7L
-2006 Acura TSX (Euro Accord) 2.4L
All were gasoline engines, so check on compatibility of any product before using in a Diesel application. I'm not necessarily promoting Seafoam or AutoRX -- just what I've experienced and heard.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
