Old 08-30-2009, 06:50 PM   #8 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
Originally Posted by vtec-e View Post
I must also point out that in a diesel engine there is a vacumn pump providing the vacumn to the brakes.
Good thing I didn't suggest to dump it into the throttle body. I often forget about the vacuum setup on Diesels.
"Clean as you drive" would be a great system -- especially if someone is tailgating A little pump of the agent into the line once a month would keep the neighbors a lot happier than the 4-alarm smoker! I might perform the procedure off-site next time -- That Ford/Mercury really smoked-up the city -- for at least 10 minutes or more.
Well, that may leave a tank additive for the Diesel...
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
