The energy you get from the batteries is the same, but losses are a function of the current. Energy is power x time eg watt-hours.
But the losses in the system are a function of the current squared . So if you reduced the current by half, you reduce the losses by 4x, even though you are getting the same power (( volts x amps) .
That is why higher voltages are gaining popularity.
