Old 08-31-2009, 06:35 PM   #29 (permalink)
Clev
Wannabe greenie
The Clunker (retired) - '90 Accord EX sedan
90 day: 29.49 mpg (US)
Uranus - '04 Ion 2 sedan
90 day: 38.21 mpg (US)
Mountain Goat - '96 Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '010 Agility 125
Originally Posted by Silveredwings View Post
Another example of the emis inline drive shaft mounted motor:
Yeah, that's kind what I was getting at. It doesn't look like Netgain did anything special to that except bolt on a U-joint at each end. (The EMIS box is actually the motor control bit; looks like they use a standard Warp motor.)
One person on the EVDL has two ADC 8" motors belted together, and another had three 9" motors mounted end-to-end. In both cases, the motor closest to the transmission must handle the torque from the other motors. In both of these cases, the standard ADC shaft was sufficient. There might be a slight possibility of concern in the case of using the 4WD low range for something like pulling a stump, but even then, half of the torque is going to the front wheels.
