Old 09-01-2009, 12:01 PM   #11 (permalink)
theycallmeebryan
2003 Ninja EX250 - '03 Ninja EX250
90 day: 87.63 mpg (US)
Saturn - '99 SL1 Base
Originally Posted by marcexec View Post
Regarding my attempt to fill her only every 1 1/2 days - that failed, sort of.
I was trying to reach the station directly at the motorway but I had to switch to reserve after 210km on the tank. I filled her with 10.35l, that's all I can get int her. The tank is supposed to hold 13 Litres + 2 Litre Reservoir.
Even worse, since coming near the "end" of the tank, probably some old gunk got loose and now she's running rough at certain rpms...
Summary:
Never change a running system!
I would drain the float bowls on your carbs, you probably have a bit of water/gunk in there.
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
