Old 09-02-2009, 11:16 PM   #3 (permalink)
FastPlastic
FastPlastic's Avatar
98 Cherokee - '98 Cherokee
90 day: 15.69 mpg (US)
ZX7R Ninja - '99 ZX7R Ninja
90 day: 39.56 mpg (US)
I would block the top, plus the outside of the bottom (including the fog light holes) where there's no radiator behind.
Test any further coverage gradually. Monitor your coolant temps closely if you have a ScanGauge (the needle on the dash, if it has one, isn't precise enough). Or listen for the cooling fan. If it's coming on more than normal, you've gone too far!
I agree. You'll see an aero improvement blocking the front and sides. Beyond that you start covering the radiator, and that can lead to some problems depending on temps and output of your cooling system. So definately take it slow if you do decide to start on the middle.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
