Old 09-04-2009, 01:58 AM   #8 (permalink)
lunarhighway
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
But people on this forum purposely build warm air intakes
yes, i've experimented with them too, and was quite surprised when i saw my FE go down... after tracing the air pickup to find it also basically gets its air from the grill i figured that what the reason a car that noticably coaster further drove worse and got worse FE.
(i have a semi urban commute so perhaps efficient acceleration has a bigger impact on my FE than top motch aero)
i've got nothing agains WAI's but i'm also sceptical how much their effect can be on modern engines. throttle restrictions are apparently i big loss factor (in fact i've just seen an article somewhere about a throttleless engine that worked by variable valve timing and got 15%-if i'm correct- better milage) and the theory behind a WAI is simple enough. in fact that might be the reason older carbed engines often had their air pickup inside the engine bay. but if warmer air only had benefits why don't carmakers fit a wai as a standard today, and compensate the loss of power with a bigger throttle?
but anyway, on the subject of grillblocks again. all i wanted to add to the discussion is that i found myself in the strange situation where a grillblock hurt my milage, but that that doesn't mean grillblock are not working (in theory... finding an alternate air pickup should allow me to run the GB)
