Old 09-04-2009, 03:49 PM   #8 (permalink)
2003protege
EcoModding Enthusiast
Silver Bullet - '03 Protege LX
90 day: 39.39 mpg (US)
The Golden Turd - '01 Grand Caravan Sport
90 day: 16.83 mpg (US)
Originally Posted by chuckm View Post
The center was flexing upward... but were the sides flexing inward? Depending on your construction and geometry, the transition from the sides of your kammback to the top may be a high pressure point. Rather than being a case of the center of the top lifting, the sides may be squeezing in and forcing the top up.
the entire outside of the kammback is almost definitely at a low pressure with [attached] flow at the speeds discussed. So the sides probably want to bow out as well as the top.
And concerning the fear of dangerous amounts of lift, I would think that unless the kammback is made from heavy guage metal, such amounts of lift would tear it off the car before it caused a huge control issue.
