Old 03-04-2008, 08:36 PM   #10 (permalink)
Red
Red's Avatar
Nice looking ZJ DPoV. My tech knowledge of ZJs is limited but do you have the e-fan as well as the fan clutch setup on your 4.0? Wondering if you have tried to running without the fan clutch and just the e-fan and see if you can increase the efficiency of the grille block some more. I'm sure you've noticed that the stock turbine can easily blow a cat off the ground when locked up. So by blocking off the grille your clutch might be locking up a bit more potentially converting any gains into the extra power required to turn it?
