Old 09-07-2009, 12:55 AM   #13 (permalink)
jpstaub
Insight 1G - '00 Honda Insight
90 day: 79.26 mpg (US)
1.2l Tdi
Originally Posted by SVOboy View Post
Could you give us a quick rundown of the specs on the TDI you put in? Will be interesting to see how the mileage does in the winter.
Good job, and welcome to ecomodder
The VW 1.2L TDI that we used from the project came from a VW Lupo 3L. The Lupo 3L was only offered in the European market (of course). As far as specs on the engine go:
Engine code - ANY
Type - 3-cylinder inline
Displacement - 1191 cm3
Bore / stroke - 76.5 mm / 86.7 mm
Compression ratio - 19.5:1
Firing order - 1-2-3
Engine management - Bosch EDC 15 P
Fuel - Ultra Low Sulphur Diesel
Exhaust gas aftertreatment - Exhaust gas recirculation and oxidation catalytic converter
Exhaust emission standard - Conforms to exhaust emission level D4.
The Following User Says Thank You to jpstaub For This Useful Post:
SVOboy (09-07-2009)
