Old 03-05-2008, 12:32 AM   #12 (permalink)
DifferentPointofView
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
Red, I have no Idea about the fan clutch (specify more please?) , but the radiator fan seems to run all the time.
anyhow it sounds like you dont have a heat issue when its a little warmer out (70 ish) i travel alot though and often see upper 80s and mid 90s any idea how much the block affects that?
As far as that goes, no. Haven't had a grille block in the summer yet because I started when it got suddenly warm in the winter (around 50) and the warmest it's been is almost 70 (67, but low 70's if your in the sun). I did get stuck testing with the block on (saran wrap prototype).
Basically, if you wanna know how much I revved the engine, basically I got it to where the back tires were smoking white smoke, in frozen mud which thawed out from the heat of the tires, and the corn with ice chunk/blocks on it melted from the heat as well. The air was... rubbery... The good news is, the temp didn't rise above about 195, which is good because the temp is around 185-190 on the highway. I've never seen it get to about 3/5ths of the way at 210, which some people run on their geo's around here anyway. So I highly recommend trying one.
Remember, you don't have to block off the whole grille at first, just bits and pieces at a time and see what happens, but the radiators on these things seem to be large enough for extreme conditions, so I wouldn't worry too much about it. That's why I blocked off the bottom first, more for aero, and then experimented with the top next.
Red, I think that might be one of the things to why it never overheated, cause I've noticed the fan can INDEED probably blow a cat down the street.
No pics again, it's been raining for over 24 hours, and it just turned to snow.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
