Interesting numbers from Toyota.
I would suggest that anyone contemplating a grille block should also look at how you can make the air that you do let in do a better job of cooling, maybe some form of ducting to get the air to the radiator. This would potentially allow even more grille block. My 93 Trans Am has NO grille. All cooling air is ducted from below ahead of the air dam.
